enable switch bluetooth
enable switch bluetooth {discovery | pairing }
Description
Enables Bluetooth capability on a switch.
Syntax Description
switch Designates enabling switch capabilities.
bluetooth Designates enabling Bluetooth capabilities on a switch.
discovery Sets discoverable mode of the switch. Default is enabled.
pairing Sets pairing ability with other Bluetooth-capable devices. Default is enabled.
Default
By default, discovery and pairing modes are enabled.
Usage Guidelines
Using the command with no options enables Bluetooth capability on the switch. The discovery and pairing options set discoverable mode and pairing ability, respectively.
To disable Bluetooth capabilites, use the disable switch bluetooth {discovery | pairing } command.
To view Bluetooth and discovery/pairing status, use the show switch bluetooth [statistics | inventory] command.
The following example enables Bluetooth capability on a switch:
# enable switch bluetooth
The following example enables discovery mode on a switch:
# enable switch bluetooth discovery
This command was first available in ExtremeXOS 30.3.
Platform Availability
